Date format - how do you set mm/dd/yy
How do you set the formats for all the date fields to to mm/dd/yy? Thanks Bill N4iQ
Re: Date format - how do you set mm/dd/yy
Log4OM uses Windows OS date format settings.
For Window's 7, click on the date and time in the lower right corner, then click Change date and time settings, in the next window click Change date and time, in the next window (thanks Microsoft...) click Change calendar settings. You will then have the Customize format window. The Short date and Long date formats can be selected from the drop down choices.
Doug - W7DRM
Doug - W7DRM
Tanks Doug - Appreciate your reply. Makes sense now. Bill N4iq
