communication with Fldigi
WA4THR
Post by WA4THR »
I am using the latest Log4OM and the latest Fldigi with a Ten Tec Omni VII. They play well together, and I even have a pan adapter linked where they use OmniRig to communicate and then Log4OM links to Fldigi to pass frequency info and retrieve log data. I was loving this, but found a problem. In any CW mode, UCW or LCW, the waterfall frequency display on Fldigi is backwards. The tuned frequency appears on the left side as it should, but instead of counting up as you move to the right, it counts down. In any other mode selected at the rig, USB/LSB/AM/FM the frequency display always correctly appears, but in either CW mode it is backwards. A comment on the Fldigi form suggested it may have to do with how Log4OM passes the information to Fldigi in XML-RPC. Has anyone seen this issue and have any idea how to correct it? By teh way, if I shift to displaying audio frequency instead of radio frequency, it displays correctly. Odd.
=Vic=
WA4THR
Re: communication with Fldigi
No its the Omnirig Ten Tec ini file, I think the CW modes are reversed - Check the Ten Tec user guide command structure against the Omnirig ini file
