On the external logs tab for LOTW you are required to put in the station ID, the TQSL Station Location Name. It must match exactly. I travel and have 12 or so locations. It would be great to be able to have a pulldown menu of available locations which mirrors TQSL. TNX for a great program.
Dave, N4XYZ
LOTW Station ID PULL DOWN MENU
Re: LOTW Station ID PULL DOWN MENU
Hi Dave, if you create multiple profiles (you can clone the actual one changing only the relevant parameters) you can have multiple configurations (including LOTW/EQSL) and personalized address/county/locator informations.
Just switch the configuration when you need to add QSO from another location, everything will be retrieved from that config, TQSL config included.
You can still use the same database for all.
