Hi All
I have downloaded wsjtx 1.6 and it works fine until i open log4om and then it looses cat control of my rig,
I have the latest version of omnirig, I have both programms running as an administrator,
any ideas whats going on,
Trevor
WSJTX 1.6 and Log4om
Re: WSJTX 1.6 and Log4om
EI2GLB wrote:Hi All
Trevor
Are you also employing JTAlert?
Have you set up as described on pages 182-183 of the user guide?
Hi Daniele,
i think that´s not a Log4OM problem nor a problem with WSJT-X or JT-Alert. Omnirig can handle more than one software on a hardware serial com but it looks like that it not works with virtual com ports ....
I have the same problem that i have to set the band manually when i work with WSJT-X and Log4OM .... My CAT/Digi Interface is a SB-1000 by CG antennas and it works with a virtual COM 3. If Omnirig is connected to my old IC-735 via this modem WSJT-X can´t grab the frequency from Omnirig ...
Bad thing but is as it is ....
B.t.w. logging via JT-Alert works great. Good Job of VK3AMA
Hi Terry
I found in another post that I need to select omnirig 1 and not my actual rig in WSJT-X
Trevor
Trevor
A possible solution is to implement a wrapper before omnirig that is able to accept multiple connections to be forwarded to Omnirig/Hamlib/Flrig
I'm thinking about that in Log4OM V2...
