FSQ (Fast Simple QSO) and eQSL
Hi Everybody,
Just a heads up that if any of you are logging FSQ QSO's?
FSQ is not a mode recognised by eQSL so your QSO uploads using that mode will be rejected by eQSL.
I suggest that you log these QSO's as SSB, which of course they are, and record that they were FSQ QSO's in the comments field
HB9BRJ
Re: FSQ (Fast Simple QSO) and eQSL
Post by HB9BRJ »
Also LOTW doesn't accept FSQ. In modelist_user.csv I mapped FSQ to MFSK16, a mode which is generally accepted. Had a few QSO just after FSQ was presented in QST, but activity was low. Maybe this has changed in the meantime.
73, Markus HB9BRJ
