updating call sign
kd2kjy
updating call sign
Post by kd2kjy »
I'm still learning this fantastic program and am trying to get through all the documentation.
I have applied for a new vanity call sign. When/if I receive it, what is the preferred method of updating my call sign in Log4OM. I don't need separate QSO logs, I'd like to keep it all together. Not sure if I should create a new config file, change databases, or just update my existing config info.
Many thanks,
Ed
w0ls
Re: updating call sign
Post by w0ls »
Ed...Just go to Settings/Options/Station Info and enter new callsign in "station callsign" and "operator callsign". That's it....
Harry
W0LS
Log4OM doesn't separate statistics.
If you want to have separated statistics you should use another profile with a different database file.
The only part where station callsign is used is in LABEL PRINTING, where you may have different QSL for each variation of your callsign/for each callsign
kd2kjy
Post by kd2kjy »
Ok, great, that's kind of what I thought but wanted to make sure I wasn't missing something that would come up later.
Thanks,
Ed
