F7 : Worked Before : Displayed Bands?
KA4CDN
Post by KA4CDN »
How do I select the bands shown in the Worked Before grid when displaying "QSO Information (F7)"?
I am showing bands 80, 60, 40, 30, 20, 17, 15, 12, 10 and 2
I want to inclue 160.
The list:
Does not match the BsandList_user.txt.
Does not match the Settings "Cluster filters" check box list.
Does not match what is shown in the User Manual (version 09/08/2015 11:46 AM) pg 41
Mike
PS - can't figure out how to search the forum for this answer. In fact I have rarely had success searching for anything on this forum FWIW
Re: F7 : Worked Before : Displayed Bands?
Mike,
Let me understand this clearly, are you saying that you have QSO's logged in Log4om on the 160 meter band but when you enter one of those call signs that you know to have been previously worked on 160 meters it does not display these QSO's in the QSO Information (F7) window?
KA4CDN
Post by KA4CDN »
No.
When I have entered a call sign into the Callsign field (but not pressed enter yet), Press F7 to see "QSO Information". There I see the world map (with my qth and the station's QTH marked). To the right of the world map is a listing in grid format labeled with the country (or state). The grid has rows for Bands and columns for Modes. I have the Bands I indicated (each in a separate row) but there is no row for Band 160.
I could do a screen capture if necessary.
Thanks Terry.
Mike
w0ls
Post by w0ls »
Hi Mike..Go to Options/Qsl and Labels. You will see a column of check boxes called Statistic Filters. Make sure 160M is checked there.
Harry
W0LS
KA4CDN
Post by KA4CDN »
Thank you. I found it this morning fumbling around when I went to change my defaults for Sent and Received.
So many options.
Thank you to the authors of Log4OM.
Mike
