I have installed new rig in my shack and connected it to separate COM port. I use OmniRig to control rigs.
Previous rig was set as RIG1 works fine. As I will use it from time to time I wanted to leave it's settings intact so I set new rig as RIG2. That did not work. No communication to RIG2.
Finally, I set new rig as RIG1 and it works. Have I done something wrong or RIG2 option does not work?
RIG2 - bug? - No it is not
Re: RIG2
The Rig1 and 2 facility with Omnirig works fine and my test results are shown belowyt9tp wrote:I have installed new rig in my shack and connected it to separate COM port. I use OmniRig to control rigs.
Rig 1 Icom IC7600 using a US Interface Navigator unit Com 3 19200 Baud
Rig 2 Icom 7100 using the standard Icom USB interface Com 16 19200 Baud
Best guess is that you have an interface or set up issue
Re: RIG2
Thanks. AT least I know it should work fine.
Trouble is that I set everything the same. If I set as RIG2 it does not work. If I set as RIG1 it works.
Re: RIG2 - bug? - No it is not
That was the first i did check. I have the latest OmniRig.
Pedija please do the following:
rename/delete current program log file
start log4om
enable debug mode
start cat
switch to rig 2
try some operations
send me the logfile
start log4om
enable debug mode
start cat
switch to rig 2
try some operations
send me the logfile
