Error saving config.xml
WB4M
Post by WB4M »
Under the "Settings 2" tab, External Software Start, I am trying to enable FLDigi. When I try to save the configuration, I get error message saying Access to the path C:/Users***etc config.xml is denied. I run Log4OM as administrator. How do I correct the error? Running Windows Vista.
Re: Error saving config.xml
Dear ????????
Sounds like the folder that you have chosen to save to is read only, go check the windows permissions for that folder and its contents
