Resource usage
G4DWV
Resource usage
Post by G4DWV »
I mentioned on the Flex forum that I used Log4OM and it was having a full re-write. A fellow user commented, "I use Log4OM as well but I find it a resource hog.... if I keep Log4OM open more than 24hrs it creeps up in excess of 500MB of memory usage. I do hope this new version addresses this issue". He also mentioned that the mem usage seems to go up and down without apparent reason.
I have attached the screenshot he posted too.
I offered to pass this on and the other user accepted my suggestion.
73 de Guy G4DWV/4X1LT
Re: Resource usage
I will check, but there aren't "growing" things that mounts on Log4OM code... also cluster is purged when record is older than 1 hour...
