Logged Frequency is TX; can it be changed ?
Posted: 17 May 2016, 10:29
by hb9cat
working DX means frequently working in split; Log4OM (through Omnirig) is showing
- VFO A as RX Frequency
- VFO B as TX Frequency
This is all fine; my problem is that the QSO gets logged based on TX Frequency, I would prefer to log it based on RX Frequency.
Can this be changed in setup ?
Marco HB9CAT
Re: Logged Frequency is TX; can it be changed ?
Posted: 17 May 2016, 10:48
No it cannot be changed by the user
You could of course display the RX frequency in your recent QSO list etc if you wish to?
The TX and RX frequencies are logged using the standard ADIF format
The TX frequency saved to ADIF field 'Freq'
The RX frequency is saved to ADIF field 'Freq_RX'
- Capture.JPG (53.98 KiB) Viewed 3456 times
To enable the universal exchange of amateur radio data 'Amateur Data Interchange Format
Posted: 21 May 2016, 05:54
by VK7XX
hb9cat wrote:Hi,
Marco HB9CAT
Marco, I can overcome this problem by swapping the TX / RX vfo's (IC-7800) . I either swap and use VFO B for TX (or RX depending on how your radio works) .... or I swap VFO's immediately before logging the QSO. works for me & saves me editing the contact.
John
