eQSL uses a 60-minute window to confirm a QSO.
It appears Log4OM uses something less than that.
I just had a "no match" from eQSL on a QSO that was logged on hour off by the other side.
I could bug him and try to get him to correct it...but since eQSL is already showing a match seems Log4OM should also show the match.
de Mike W9MDB
eQSL 60 minute window
Re: eQSL 60 minute window
We use the same time interval tolerance for a QSO match that LOTW use, which if I recall is 15 or 30 minutes, a QSO logged over an hour different should not be matched IMHO
It's plus/minus 30 minutes which is an hour window but not an hour difference.
