Page 1 of 2
Problem with Win10 upgrade
Posted: 04 Aug 2016, 11:33
by w5uy
Hi All:
Don't know what changed, but after the upgrade to the Win10, I cannot run Log40m. It has been running without a hitch for many months, but now when I try and run the program, I get an interrupt screen indicating that Log40m has stopped running. Anyone else having a similar problem?
Any solutions would be appreciated.
Thanks for any help.
73, Bill, W5UY
Re: Problem with Win10 upgrade
Posted: 04 Aug 2016, 12:09
Try installing the latest version of Lop4OM (Version 1.25) as an administrator
Posted: 04 Aug 2016, 12:28
by w5uy
Terry
Did try it that way but no joy.
Bill
Posted: 04 Aug 2016, 15:48
Did you uninstall the old version before installing the new one
Have you set the Windows 'User Account control' to minimum, if not please do so and also suspend any firewalls and antivrus software during the install
Posted: 04 Aug 2016, 21:42
by w5uy
Terry
Well, I still haven't got it working yet---I have turned off the firewall, put the UAC on minimum, turned of BD Ant-iRansomware
I don't think I have any other things running. Now, I have not deleted the original Log40m file because I was unsure how to do it without deleting the program configuration files, etc. Also, I have heard much about the problems with Java, so I am going to delete it. So, I am off the air until I can get Log40m running. Any help would be appreciated.
Bill, W5UY
Posted: 06 Aug 2016, 16:38
by NN7D
Hi Bill,
I will contact you directly and see if I can help resolve your issue. Do you have TeamViewer installed on your computer (which Log4OM is on)? If not, could you install it - free version.
Thanks,
Doug - W7DRM
Posted: 06 Aug 2016, 17:32
by w5uy
Hi Doug
I sure would appreciate any assistance you could provide ---
I do have TeamViewer installed --- 582 789 427
If you will send me your address I will send you the password ---
I have to take the XYL our for a while---maybe a couple of hours, I will let you know when I am back
I just installed TeamView ---however I do not have a headset attached as I have not figured out how to connect a headset, media and etc while the computer setup up for PSK.
I really appreciate any help ---
thanks
Bill, W5UY
[email protected]
Posted: 06 Aug 2016, 22:52
by w5uy
Doug
I have sent you an email with my Team Viewer numbers as well as my landline
Bill, W5UY
[email protected]
575-312-5599
Posted: 07 Aug 2016, 21:27
by NN7D
Working on this issue with Bill.
BROADCAST: Has anyone else installed the Windows 10 Anniversary update and run Log4OM successfully? Please let me know if you have.
Thanks,
Doug - W7DRM
Posted: 08 Aug 2016, 10:49
Yes, it works...
