cluster wrong mode
cluster wrong mode
when viewing the cluster it is reporting 7.147 as Digital , but it is actually LSB . So if i do not have Digital selected in the filter i miss any spots in LSB in that range .
- 2.JPG (19.14 KiB) Viewed 3339 times
- 1.JPG (15.21 KiB) Viewed 3339 times
Re: cluster wrong mode
What is your current region in settings screen? (2nd tab of settings)
Region 2 Ohio , USA
We have a bandplan system based on regions.
For dxcc 291 and 221 we have 2 personalized bandplans (more can be added for other dxcc's)
If you set your DXCC as 291, as it should be, you're using the "bandplan_dxcc291.xml" in your program config folder / bandplan (you can find the folder from help menu)
The bandplan for 40mt:
This is what we set for USA, but you can change it based on your preferences (well, it should be correct, i hope, as it is), changing the upper limit and moving the start limit of the subsequent area to avoid gaps.
Make a copy of the file and rename it appending a _user.xml to avoid rewrite on next update.
You can see that the END of digital area is 7150, in this file.<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7035</End>
<BandUpperLimit>false</BandUpperLimit>
<EmissionType>CW</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7035</Start>
<End>7150</End>
<EmissionType>DIGITAL</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7150</Start>
<End>7300</End>
<BandUpperLimit>true</BandUpperLimit>
<EmissionType>PHONE</EmissionType>
<ModulationType>LSB</ModulationType>
</BandPlanRange>
Daniele, thanks for the help and the reply . As always first class all the way with Log4Om
