All of a sudden my Log4OM is crashing after about 2 minutes after starting.
I ran 1.25 on Windows 7 Pro for a long time without any problem.
After I had my PC restart (controlled) after several month this problem occurred suddenly.
Everyting seems to work normal (CAT/Cluster etc).
I have only the MicroHam MKIIR software running and Log4OM.
I tried several tinmes (restart PC and start Log4OM) but no positive effect.
Then I installed 1.26, but the same problem.
Any suggestions?
Thanks in advance
73's, Evert PA2KW
Log4OM crashing
Re: Log4OM crashing
Try uninstalling Log4OM and then do a clean install remembering to right click on the installer exe file and select 'Run as administrator'
MAKE A BACKUP
MAKE A BACKUP
