I have imported ADIF files from three ARRL Field Days and one NAQP, all logged with N3FJP software, 288 total QSOs.
There are duplicate callsigns in these logs. For example, I have Arizona callsign in two separate FD's (one year and 10 minutes apart, which I find entertaining) and the NAQP. Some might say they are not *technically* duplicates because the times and dates don't match, so I don't think the ADIF import engine ignored any of them and obviously, I can find them all manually by sorting by callsign and just scrolling down the list.
The trouble is that I want to upload these logs to LOTW and TQSL gives me an error when I attempt it. It says that it found a duplicate on line (whatever, 8 I think) and gives me the option to continue signing the file ignoring the error or cancel. If I ignore, it seems to hang at that step, never doing anything else. I can close the dialog box. Once I have done this one time, subsequent attempts give the following errors:
No records to upload
Final Status: Unknown (13)
Unrecognized Answer from TQSL. Value is 13
OPERATION COMPLETED
A bit of Googling indicates that error 13 has something to do with the duplicates database being locked. I can't help thinking that closing the dialog box after waiting for no more updates in the original upload attempt might have left the database in a bad state.
I need to unlock the duplicates database, but I also need to solve the original problem, where it seems to shine on a duplicate QSO
Sluggy!
N5HRK
TQSL duplicate error
Re: TQSL duplicate error
Log4OM interacts with TQSL to upload files. It has nothing to do with the program internal database, that is mantained internally by TQSL.
Where you have found about error 13?
