I am using v 1.24.0.0 of Log4OM running OmniRig with a Ten Tec Omni VII and a SignaLink. It all works great. I have been able to record off the air using the SignaLink as the soundcard, and it plays well through the speaker and keys the radio. But, I would like to be able to pull that recording and send it via email to another ham. This is very handy when doing audio adjustments over the air. I have searched for an audio file that is created, but unable to find one. Is there a way to do this?
=Vic=
WA4THR
Capturing audio
Re: Capturing audio
First, the latest version is 1.26. You should down load and install it.
Second, Log4OM is in a maintenance mode only while V.2 is being worked on.
Third, currently there is no means to capture audio. Possibly v.2
Chuck K7PT
Chuck K7PT
Re: Capturing audio
Vic,WA4THR wrote:I am using v 1.24.0.0 of Log4OM running OmniRig with a Ten Tec Omni VII and a SignaLink. It all works great. I have been able to record off the air using the SignaLink as the soundcard, and it plays well through the speaker and keys the radio. But, I would like to be able to pull that recording and send it via email to another ham. This is very handy when doing audio adjustments over the air. I have searched for an audio file that is created, but unable to find one. Is there a way to do this?
=Vic=
WA4THR
The recording system in Log4OM is only intended to record voice messages for our voice keyer and although you could use the files which are stored in the C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\audio folder this would be a bit ponderous.
I use the free program Audacity in which you will be able to select your Signalink audio codec and is very easy to use ith an export to many audio file formats.
