I'm trying Log4OM and Now I want to configure the Rotor interface
I'm reading the Help File in French
I downloaded PstRotator V13.46 in demo mode
I always use the Administrator rules to install
In the documentation the first things to do is to select Log4OM in the Setup menu
But in this menu I have not Log4OM
I have N1MM, Logger32, Win-test ...but no Log4OM
From the Log4OM I configured correctly (I think) the communicator because when I click on the "Start" Button the "TCP Connection to Log4OM" be come green
When I use in Stand-alone PSTRotator it works fine, If I tape a call into the PstRotator and click "GO" the antenna is running well
Can you help me about this configuration Please ?
Dan
PstRotator Doesn't works with Log4OM
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: PstRotator Doesn't works with Log4OM
I think you have downloaded the wrong version of PST Rotator, only one version is set up for Log4OM and I believe its the EL version not the AZ/EL or perhaps its the other way round
Hi Terry
Once again you are right
I Downloaded the AZ+EL Program (PstRotator.exe) instead of AZ program (PstRotatorAZ.exe). Now that works fine ....
Thanks again Terry
Dan
Hi Terry
Thanks again Terry
Dan
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
