Browser do not allow to login into qrz.com
IZ3XNJ
Post by IZ3XNJ »
Hi
recently I've noticed that if I go to qrz.com website from internal LOG4om browser, I am not able anymore to login because qrz's home page complains:
You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Not a drammatic issue, but it was useful to lookup a call and take a look to extended infos ....
I believe that when QRZ.com implemented the new (ugly, in my humble opinion :) ) look for their hompage, they had to test browser compatiblity, but as Log4OM is written in .NET I imagined that Log4OM used the components of the Internet Explorer, which instead is compatible....
73 de IZ3XNJ Stefano
Re: Browser do not allow to login into qrz.com
IZ3XNJ wrote:Hi
I have just checked this with my Windows 10 machine using the default browser and log in works fine! have you tried updating Windows to see if your browser requires updating?
IZ3XNJ
Post by IZ3XNJ »
G4POP wrote: I have just checked this with my Windows 10 machine using the default browser and log in works fine! have you tried updating Windows to see if your browser requires updating?
Yes, all browsers on my PC are updated to latest versions and all of them can correctly login into QRZ, even Internet Explorer. I just can logon from Log4OM browser...
IZ3XNJ
Post by IZ3XNJ »
Sorry, my fault :oops:
The message it is only related to the homepage new style.
Logon works perfectly, it is just me growing older.... :oops:
