good afternoon
When typing an on-screen prompt to add a new qso, it does not search the contact's locator grid, is this normal? Or did I stop doing some configuration ?? I use search on qrz.com.
Clicking on the call sign in the cluster, yes, the same after the information of the grid locator!
thank you!
pp5xa - xavier
Grid locator does not appear when you enter a call sign
Re: Grid locator does not appear when you enter a call sign
Hello Xavier,
a normal thing if you are QRZ ham member. Full search is only availible for payed XML subscribers. Better using Hamqth for the lookup. But think about it, not each Ham writes his locator into his data. But that´s not Log4OM problem when a locator is not availible on a lookup service ...
OK My friend, thank you very much!!!
