Not connected?
kc9lif
Not connected?
Post by kc9lif »
Hi All,
I have been using v.1.27 for some time now without problems. However, when I first open the program I get a message that says "not connected" as the screen shot shows. The frequency indicates what my KX3 is set at. I am not sure what that means???? I then open winkeyer and everything appears to be working fine. Any ideas what the issue is??? Apologies if it is in the manual and I missed it. :oops:
Thx, et 73, Kent KC9LIF
LOg4OM_not connect.jpg (148.44 KiB) Viewed 3218 times
K7PT
Re: Not connected?
Post by K7PT »
It means the cluster your attempting to connect too is either down or your internet connection is down. Try another cluster and it will probably connect.
kc9lif
Re: Not connected?
Post by kc9lif »
Thanks, Chuck. I will give that a try...FB :D
Re: Not connected?
Please let us know what the cause and cure was?
n6oil
Re: Not connected?
Post by n6oil »
Just as an FYI, I too get this when I'm connected to VE7CC cluster and I'm sure it's when my internet connection burps at home. No big deal I just reconnect to the cluster and all is good also I think you can check the box "keep alive" and that might help.
