Hamlib update help pls?
I'm trying to get the updated Hamlib application and rig control files in the proper location so Log4OM can utilize them.
I'm sure I've not downloaded some additional file from Sourceforge that has the rig files or DLLs. Log4OM has the 'point to' for HamLib under the Roaming/LogOM/hamlib directory structure.
Thanks in advance.
G4DWV
Re: Hamlib update help pls?
Post by G4DWV »
The structure of the latest Hamlib seems to be completely different to the older version in Log4OM. There are no rig-labelled DDLs for example. I wonder if it is possible to do a complete swap or not for the older version?
73 de Guy G4DWV/4X1LT
It is different and requires coding into Log4OM, as version 1 of Log4OM is on maintenance this will not be implemented until version 2.00 of Log4OM
