LoTW Filter not Working
Posted: 11 Apr 2017, 17:54
by K2RAS
I am running version 1.28.0.0 and noticed that when the LoTW filter is checked no spots are now returned. Is anyone else having this problem?
Thanks, Ron
K2RAS
Re: LoTW Filter not Working
Posted: 11 Apr 2017, 18:02
by DF5WW
Hi Ron,
if you mean the Box "LoTW Users" it is working fine here. If i check the Box only LotW users would be show´n in the cluster window.
B.t.w. that is only working in the F9 Window, not in the seperated small cluster on the right side.
Posted: 11 Apr 2017, 18:56
by K2RAS
Just confirming, are you using version 1.28?
Thanks, Ron
Posted: 11 Apr 2017, 19:58
by DF5WW
Yes ... have it running since the first beta tests ;) :D
Posted: 12 Apr 2017, 20:00
by K0AY
I'm experiencing the same thing with the latest release. No stations are showing LOTW in cluster.
Posted: 12 Apr 2017, 20:20
by DF5WW
Some screenshots
Posted: 12 Apr 2017, 20:24
by K7PT
V1.28:
Make sure you have downloaded the latest LOTW user file (4/12/2017) using the "settings" drop down.
Mine was not working until I did the down load after installing 1.28.
Lele may want to check why this is.
Posted: 12 Apr 2017, 21:15
by K2RAS
That, and a program restart fixed it. Thanks,
Ron
Posted: 12 Apr 2017, 21:51
by K0AY
If I check the box "LOTW users" then, I get only LOTW users. I want to see all spots with LOTW user's time in red, as before.
Posted: 12 Apr 2017, 21:52
by K0AY
Whoops, I must have done something. It's now working ! :P
