Database or disk is full-error
Why am i getting this error?
Re: Database or disk is full-error
I have deleted your log file, as it may contains sensitive informations.
It seems your database is corrupted. You should restore from the last valid ADIF backup.
In the meanwhile please send me your corrupted DB (zipped) so i can check what happened.
Probably it was wrongly copied/exported externally.
Do you use GOOGLE DRIVE/DROPBOX for storing the DB?
That did it! Many thanks. Yes, I had the wrong database selected. I had problems with my computer and did a restore to a previous backup. That's when my problems started. I I lost the location of my main log file. In settings 1, In clicking "view config Path", a box opens up, but it is not wide enough to show the last part of the location. So I picked the wrong SQlite file. All is OK now. Thanks again.
Art
K0AY
Art
K0AY
