Auto Load JT65 Contact Stopped
K6RWM
Post by K6RWM »
It appears that the latest Windows 10 critical update, released yesterday, may have broken the QSO auto upload to Log4OM. It was working fine prior to Windoze installing the update and restarting. I have shutdown HRD, WSJT-X, JTAlert, and Log4OM and restarted them several times to no avail. I have checked the port settings, etc, and all are correct.
Anyone else have this problem? Any suggestions much appreciated.
Thanks.
Bob -- K6RWM
K6RWM
Re: Auto Load JT65 Contact Stopped
Post by K6RWM »
Well, after a second restart, the auto log is working again. Not sure what happened in the process, but all is well.
I have noticed after Windows restarts, that Log4OM seems to be happier if it is started prior to HRD, WSJT-X, and JTAlert.
Thanks.
Bob -- K6RWM
K6RWM wrote: 11 May 2017, 07:28 Well, after a second restart, the auto log is working again. Not sure what happened in the process, but all is well.
Thanks.
Bob -- K6RWM
Does HRD now have Omnirig support or are you using a VSP?
