Skimmer spots in cluster window
IK2KAW
Post by IK2KAW »
Hi all,
if I enable the reception of skimmer spots on cluster (I use k1ttt.net) they are apparently processed in the right side window but they are not processed in the main cluster window.
Hovewer, If I try to connect directly to RBN (telnet.reversebeacon.net:7000) the (skimmer) spots are correctly processed and merged !
Could you please advise me how to deal with this problem ?
Many thanks,
Rik, IK2CAW
Re: Skimmer spots in cluster window
Hi Rik,
I believe we have had this before and it was something to do with how K1TTT presents the data.
Perhaps Daniele can help?
I need to check what is coming up from CW SKIMMER... Never used yet :)
Terry, can you add a MANTIS issue about that with some details for me to start searching for the issue?
p.s. a DEBUG MODE flag enabled in settings will save all messages from cluster in a cluster log file in the roaming folder. This could help me finding the issue soon
lele
Yes will do but it's not CW Skimmer it's an AR cluster node that causes the issue
