Integration with Win4Yaesu
M0XMX
Post by M0XMX »
Hi All.
Trying hard to get this to work.
Using com0com to create virtual com ports. Assigning one of them to omnirig and then pointing Log4OM to omnirig.
When I do this everything seems to work fine EXCEPT, the VFO on Log4OM is 100Mhz too high. (see attached)
Any thoughts or ideas?
Mike M0XMX
Re: Integration with Win4Yaesu
Are you certain that you don't have a transverter offset set in Log4OM Options/CAT & Cluster - default is 0.000 (=No offset)
