I am proud to say I have exported my Excel logs into Log4OM. I had not used ADIF files before but after some research, I was successful in getting all my records into Log4OM. Now I just have to dig out two books of old paper logs from the early 80s and get those in LOG4OM too.
But my question is this. On occasion I want to be able to view only Sota contacts in the Recent QSO window. I have tried several different searches but have not been successful. I am sure it is something simple but am missing it. I would actually like to have three searches, Sota All, Sota Chaser, and Sota Activator.
Any help will be appreciated.
By the way, Log4OM I am finding out is just awesome! Congrats to the developers for making something that hams can actually find useful.
73, Ron
Sota Display
Re: Sota Display
KI4TN wrote: 28 Sep 2017, 04:43 I am proud to say I have exported my Excel logs into Log4OM. I had not used ADIF files before but after some research, I was successful in getting all my records into Log4OM. Now I just have to dig out two books of old paper logs from the early 80s and get those in LOG4OM too.
73, Ron
Search Parameters
Set search parameters like this...
My SOTA Ref - if Not equal to - leave data field blank (Displays all records where the My SOTA filed is NOT empty)
or
SOTA Ref - if Not equal to - leave data field blank (Displays all records where the SOTA filed is NOT empty)
or Use both parameters to display those records where there are SOTA references in both fields
Re: Sota Display
So simple. I was reverting back to my old days where database syntax was different and using this type of format:
SotaRef Not Equal " "
The quotes with only a space between in the old days indicated a blank field. I didn't think about not entering anything, which is obviously much easier.
Thanks and 73,
Ron
Thanks and 73,
Ron
Re: Sota Display
KI4TN wrote: 28 Sep 2017, 06:36 So simple. I was reverting back to my old days where database syntax was different and using this type of format:
Thanks and 73,
Ron
Don't forget that you can save these searches for quick recall at some later date
