CAT control for Yaesu FT 891
How do I control my Yaesu FT 891. I tried omnirig. What are the settings in my Yaesu FT 891? Please help. Ram, VU3RCN
Re: CAT control for Yaesu FT 891
Hi Ram,
i don´t have one but first off all you have to check the menu items for CAT in your radio. You may find the
way to check it in the manual of your transceiver.
In Omnirig you have to set the correct COM port for your radio and you have to use the same baud rate,
bits and stopbits like described in your radio manual.
Hope this helps a bit. If not i hope we have another FT-891 user here with us
Please! help messages are next to useless you must provide more information for us to help, like the example below.ramsiyer wrote: 06 Nov 2017, 16:22 How do I control my Yaesu FT 891. I tried omnirig. What are the settings in my Yaesu FT 891? Please help. Ram, VU3RCN
e.g. I have connected my FT891 to my computer using an XYZ interface cable and selected the correct com port in Omnirig but the cat light in Log4OM stays red - Help please?
You must refer to the 891 manual to set the baud rate and then select the same baud rate in Omnirig
You must also know what com port on the computer the radio is connected to and choose that in Omnigig
Thanks to one and all. I got it connected finally. Here are the settings for FT 891. Choose FT 991 for these settings in Omnirig and choose the enhanced COM port.
05-06 CAT RATE 4800bps
05-07 CAT TOT 100msec
05-08 CAT RTS Enable
07-11 CW FREQ DISPLAY FREQ
08-01 DATA MODE OTHERS
08-03 OTHER DISP 1500Hz
08-04 OTHER SHIFT 1500Hz
08-05 DATA LCUT FREQ OFF
08-07 DATA HCUT FREQ 700Hz
08-09 DATA IN SELECT REAR
08-10 DATA PTT SELECT RTS
08-12 DATA BFO USB
08-12 DATA BFO USB
You might want to try changing the baud rate in the 891 menu and also the Omnirig menu to something higher to obtain a faster and smoother response, try 19200 or aboveramsiyer wrote: 08 Nov 2017, 02:25 Thanks to one and all. I got it connected finally. Here are the settings for FT 891. Choose FT 991 for these settings in Omnirig and choose the enhanced COM port.
08-12 DATA BFO USB
Yeah, you are right. It works on 19200bps. 73
