Hi all!
Is there a walk trough how to use log40om with more ident's ? My YL want to use log40m at the same computer. Is there an option ore trick how to use more call's with log40m? We also use a clubcall we need to log with it. So we talk about 3 call's. I do understand that it is in another log.
Hope i will find an answer, thanks in advance
73 PD8B
working with another ident (call)
Re: working with another ident (call)
Just create a new profile and logbook database as if it's the first time.
See the user guide and YouTube tutorials regarding setting up a different Configuration
Another method would be to set up a portable installation for the second call. I do that with my wife's call, and can have both logs running at the same time. I have different shortcuts for the two calls. Each log has its own configuration. Since you asked about three calls, including the club call, you might need to have two portable installations in two different locations. I haven't tried it with three logs, so don't know if it will work for that purpose.
Jim N6VH
Jim N6VH
