Select config at startup
w9mdb
Post by w9mdb »
Can one select a saved configuration at startup?
Is there some command line switch to do this?
de Mike W9MDB
Re: Select config at startup
You can have different desktop shortcuts for each configuration if you use the Config ID in the shortcut path
NR3E
Post by NR3E »
I did a search of the forum and found this article. I am interested in doing this, but can't seem to get the syntax right.
My shortcut has to following command line in the target:
"C:\Program Files (x86)\IW3HMH\Log4OM\LogOMUI.exe"
I have tried typing CONFIG=xxxxxxxxxx after LogOMUI.exe with a space, slash, backslash, and colon, but nothing works. Any help would be appreciated.
Thanks,
Ron, KI4TN
HB9BRJ
Post by HB9BRJ »
I'm using shortcuts for each of my 4 configurations. Here is an example:
C:\PortableApps\Log4OM\LogOMUI.exe CONFIG=c65a98bc-22ed-4194-a673-5a962a1e3371
No double quotes needed since there are no spaces in the path. But this one also works:
"C:\PortableApps\Log4OM\LogOMUI.exe" CONFIG=c65a98bc-22ed-4194-a673-5a962a1e3371
If your path contains spaces I think the command string should look like this:
"C:\Program Files (x86)\IW3HMH\Log4OM\LogOMUI.exe" CONFIG=.....
73, Markus HB9BRJ
