plotting grid squares to google earth
I4OQA
Post by I4OQA »
Where in this forum may i find more material to read covering the subject above mentioned ??
When you say Google Earth, you mean also Google Earth Pro ???
HOW TO SORT AND SELECT QSO'S BY BAND ????
Thanks and bst 73 de i4oqa.
Re: plotting grid squares to google earth
Utilities/Google Earth Integration/ Search parameters
Select the fields that you want, I chose to search by 60m band and FT8 mode as below
I4OQA
Post by I4OQA »
Thank Yoooooooooooooooooooooooooooo!!!!
The matelial you have posted is clear !
But, it is now months, without exageration, that PLOTTING GRID SQUARES TO GOOGLE EARTH IS ABSOLUTELLY IMPOSSIBLE !!!
Read and know by memory the user manual..., loaded and reloaded many many times Google Earth and now Google earth pro. Nothing i can do to make it working !!
May be in the forum i can read some posts covering this subject,...but where do i have to go to find material ????
Happy New Year and bst 73 de old old man i4oqa !!!!
Must be some issue on your computer because Log4OM is working beautifully with respect to searching and generating grids in Google
See my 40m band contacts as displayed below using Windows 10 Creator and Google Earth Pro 7.3.0.3832
Google 1.JPG (94.47 KiB) Viewed 3729 times
Google 2.JPG (91.25 KiB) Viewed 3729 times
I4OQA
Post by I4OQA »
Hi.
Thanks.
I see!!
I run a very good almost new HP pc but still with windows 7. Probably one of the last HP pc with window 7.
I wanted to plot all my 40 meter band cw achived till today.
I'll see what to do. For the time beeing i rest ! But if i rest i rust !
Bst 73 de i4oqa.
I just tried this on a steam powered Windoze XP machine and it worked perfectly
