Small Cluster Window
N0AV
Post by N0AV »
In order to help my aging eyes I like to have the text larger so in Windows display options I changed this setting from "small" to "medium" All Log4OM windows are fine with this except the small cluster window. It makes the text larger but the spots are closer together so they kind of overlap and are harder to read. Is there a remedy for this? Am I missing a setting somewhere?
Thanks,
Jim N0AV
Re: Small Cluster Window
Hi Jim,
I have the the same problem with font size in that window so I open the F2 cluster window on another screen.
However I am not sure if Lele can fix that in the small cluster and only he could comment!
it's the eternal issue with screen size...
I will check if it's possible to put some informations in a popup screen, leaving only the callsign on the SMALL CLUSTER...
trying to experiment something... but window size is our worst enemy :(
Daniele
