Icom7610
HB9CVE
Icom7610
Post by HB9CVE »
I have do my best, but didn't get to work . Any instructions? Can not find the IC7610 in the list. Thank you for help.
Re: Icom7610
Did you try Omnirig 7600?
LA9FFA
Re: Icom7610
Post by LA9FFA »
I got a working file here for omnirig.Its from the new rigIni.zip from Alex Dxatlas.com dated 21.02.18. but it had the CW-R and RTTY-R fault, That is fixed in the attached file, Thanks to Doug W7DRM how helped with the CW-R problem. Just remember to rename it back to IC-7610.ini again. :D
IC-7610.ini.txt
(7.89 KiB) Downloaded 637 times
HB9CVE
Re: Icom7610
Post by HB9CVE »
Thank you for the file. I got it working in the meantime with the 2 faults. So happy to try your file. best 73
HB9CVE
Re: Icom7610
Post by HB9CVE »
Hello Rolf
Have just installed your file and now it works perfectly in transmitting from DX-Cluster to the radio IC-7610 in cw and rtty.
super es best 73
Andy
HB9CVE
LA9FFA
Re: Icom7610
Post by LA9FFA »
Thats great Andy :-)
Got my Icom 7610 yesterday lots of things to play with.
KL7HRN
Re: Icom7610
Post by KL7HRN »
LA9FFA wrote: 25 Feb 2018, 12:14 I got a working file here for omnirig.Its from the new rigIni.zip from Alex Dxatlas.com dated 21.02.18. but it had the CW-R and RTTY-R fault, That is fixed in the attached file, Thanks to Doug W7DRM how helped with the CW-R problem. Just remember to rename it back to IC-7610.ini again. :D
IC-7610.ini.txt
Can you (or anyone) tell me how to make Log4OM work with my IC-7610? What should the baud rate be set at on both the USB driver COM Port and within the OmniRig baud rate setting. Also what rig should be selected? (i.e., IC-7600)?
Re: Icom7610
You quoted a previous post that answers your question!
Ensure the baud rate matches to whatever you have the radio set to, I use 19200
LA9FFA
Re: Icom7610
Post by LA9FFA »
Its ok now. Ed was using the USB 1 (A) connector, and then the CI-V USB Echo Back has to be "ON"
