LOTW Temporary Path
NT6X
LOTW Temporary Path
Post by NT6X »
Hi guys, I'm not clear on what is required in the LOTW Temporary Path field in the LOTW Settings tab. Do I put in the URL for LOTW or a path to my LOTW folder on my computer?
Re: LOTW Temporary Path
Point to the LogOM folder as follows
C:\users\YOUR USER NAME\AppData\Roaming\LogOM\LOTW
it's a temporary folder where Log4OM stores the ADIF files before they will be packed for LOTW.
I suggest adding a different folder, to avoid cluttering the configuration folder. This can be everywhere, also C:\TEMP, and can be cleaned periodically (also every day)
Daniele
