hi
i can not get ts-590 sg it to connect to log40m ts- 590 is all they show i have a ts-590sg
i have 2 computer it is connect to log40m ic7600
thanks
cl
ka5mwb
ts-590sg
Re: ts-590sg
Always the same questions to a thread opener:
On which way you connect to the radio Omnirig or Hamlib ????
Did you use the latest Omnirig software and have you downloaded the latest .ini files ????
Is Omnirig installed and working under administrator privileges ????
Is Log4OM himself installed running with administrator privileges too ????
Re: ts-590sg
hi
i am using omning work great with ic7600
i try to download log40m- 1-32-0 where i would omning and new update but would not install
it said bad file
it said bad file
Re: ts-590sg
Hi "nameless",
if a installation routine said "bad file" try a fresh download. On the log4om download site
you find a download link but a bit deeper also a direct download for guy´s which have
problems with link 1.
Log4OM needs installation as administrator and also Omnirig needs this. B.t.w Omnirig
is not included in any version of Log4OM. You have to download it seperate from their
website. Pleas download also the latest .ini files for the different rigs.
I am also using a Kenwood (TS-480SAT) and all is working fine on my side.
Re: ts-590sg
got it work ok thanks had to put kenwood not ts-590
