OUT OF BAND Error
M0KCP
OUT OF BAND Error
Post by M0KCP »
I know this issue was covered before, but i couldn't get the XML file fix to work. :cry:
When operating on 60m (5MHz) LOG4OM indidicates that i'm 'OUT OF BAND' when my frequency is still within the current 2018 band plan. Specifically when I tune above 5355 kHz CW and 5371.5 kHz CW, Log4OM shows 'out of band'. The UK band plan allows operation above these frequencies, up to 5358 KHz and 5374.5 kHz respectively.
I can't find an xml band-file on my machine to edit. I'm using version Log4OM v1.34
Thanks in advance for your help.
Rob - M0KCP
Re: OUT OF BAND Error
The bandplan_r1.xml is located at c:\...........\appdata\roaming\logom\
M0KCP
Post by M0KCP »
Got it !
Many thanks
Rob M0KCP
