bug in 1.36.00 - no TX when using fldigi via XML-RPC
OK2TOP
Post by OK2TOP »
Hi, I am using fldigi with log4om using a XML-RPC connection in fldigi and a installed 1.36.00 today and a log4om communicator. After installing 1.36.00 today, there were problems with fldigi connecting to communicator. After few attempts, I managed flidigi working again, however, when I key using tx/rx button in flidigi, the rig does not key. But when change the freq on the transceiver, the freq changes in both log4om and fldigi - it is just tx that does not work. When I use PTT button in log4om, the rig keys OK. I am using IC-7300 and a 4.0.18 version of fldigi. Reverted back to 1.35.00 and everything works again. There seems to be a new version of log4om communicator in 1.36.00, i noticed some new settings.
Staying on 1.35.00 now before someone else can confirm this bug. If it's not a bug, please feel free to delete my post.
73 de Ondrej, OK2TOP
Re: bug in 1.36.00 - no TX when using fldigi via XML-RPC
Tasks for reporting. We didn't changed anything here but I will investigate
OK2TOP
Post by OK2TOP »
Hi, did one more test today and finally got it working. First, the TX did not work again, then restarted communicator and all started working. The only thing which is not working now is when I change frequency in fldigi, the frequency is not changed in the radio. But the TX works. When I change the frequency in the radio, the display in fldigi is updated correctly.
