LOTW ssb entries
LOTW ssb entries
on shutdown only ft8 logbook entries show as records, SSB entries do not show as a record so only my ft8 logbook entries are forwarded to LOTW. I would like all the entries to be fwd toi LOTW
Re: LOTW ssb entries
Frank,
As you make and complete an SSB contact (or CW) and have the contact information inserted do those entries appear in the Recent QSO (F8) tab on your Log4OM display?
Or are you only seeing your FT8 completed entries in that 'logbook' window?
Everything looks ok on the recent qso all the columns are filled out and everything looks normal. if I go to my qrz logbook the entries update to LOTW just fine. my log40m only updates the ft8 entries. This is a recent issue up until 17 February it all worked fine. I did something to screw this up, I just do not know what I did to cause this.
thanks for your help.
Frank W2gc
Frank W2gc
Frank,
Have you tried a manual upload to LotW? Does that work ok?
Doug
W7DRM
Doug
W7DRM
If I do a manual upload it works perfect. Thanks for the tip. I will use manual from now on.
W2gc
Frank Sanocki
W2gc
Frank Sanocki
