I am using Log4Om from several months and I am very happy with it.
Now I am doing some tests to use it during contests.
I was able to configure it for the CQ World Wide DX CW Contest but I can't find a way to export the log in the Cabrillo format.
What is the correct procedure to get the file in the correct format?
Thank you very much and 73 '
iw7dmh
enzo
Exporting log file in Cabrillo Format
Re: Exporting log file in Cabrillo Format
Ciao Enzo,
At this time we do not have a Cabrillo export the best thing is to export an ADIF and use one of the free ADIF to Cabrillo converters on the internet.
Cabrillo export is on our list for V2
Ok, thank a lot for your answer.
I hope to see this new function asap.
Best regards
enzo
Best regards
enzo
I have a further question about that. Having clearly in mind that I have to use another contest log which I will upload the ADIF exported file from Log4OM in and then export them in Cabrillo, my question is how may I select only the qso done in the contest to be exported?
73' de OK8GG
73' de OK8GG
Yes you can select by date/time, contest name etc in QSO manager or recent QSO windowsOK8GG wrote: ↑20 Dec 2020, 11:03 I have a further question about that. Having clearly in mind that I have to use another contest log which I will upload the ADIF exported file from Log4OM in and then export them in Cabrillo, my question is how may I select only the qso done in the contest to be exported?
73' de OK8GG
Why not just integrate with n1mm as detailed in our user guide and then n1mm will auto log to log4om and you can export cabrilio from n1mm
