New Band cluster color problem
CT1ETE
Post by CT1ETE »
Hello all,
I have green configured as the color for the DX Cluster windows on NEW BAND. It happens that the color doesn't show up. The only color I'm getting is the default red of the New Ones.
Would appreciate some help.
73 Paulo
Re: New Band cluster color problem
I dont know what your doing wrong but its working fine as you will see from the screen shot below.
Are you saving the settings?
CT1ETE
Post by CT1ETE »
I thought it would display on the window signaled in red.
vy 73
Screenshot 2019-03-18 23.34.49.png (115.74 KiB) Viewed 3227 times
As there are no band or mode columns in that window how are we supposed to highlight them?
CT1ETE
Post by CT1ETE »
There's frequency, which gives band. I mean NEW BAND and not BAND/MODE.
You will note we do not highlight the frequency in the main cluster! it is the band field and the mode field that we highlight, which are not present in the mini cluster
We will not add this function because version 1 is on maintainence only, pending the release of version 2
Version 2.0 is different and handles cluster spots and the highlighting thereof in different manner
CT1ETE
Post by CT1ETE »
OK Terry. Understood. Many thanks!
73 Paulo
