Config lost when opening Log4OM this morning.
johnnyftw
Post by johnnyftw »
Have only used Log4OM for a week or so but has been running fine without any issues, but this morning it started with no config/settings. Did some research and found that I could take the latest config.xml backup and put it in C:\Users\*\AppData\Roaming\LogOM which fixed the issue.
Just wondering if anyone has figured out why this happens and how to fix it?
Re: Config lost when opening Log4OM this morning.
Usually a corrupted XML file causes that but just what the cause is we don't know, could be a bad disk segment or something like intrusion from a virus or malware.
Let us know if it happens Again and we will check out your set up for you
