No download from LoTW anymore
on6hk
Post by on6hk »
I noticed at the LoTW website that I had a couple of new QSL confirmations.
When I wanted to download these in LOG4OM, I got the following data in the LOTW download window
> 22/04/2019 19:05:53: Begin ADIF generation request
> 22/04/2019 19:05:53: login on6hk
> 22/04/2019 19:05:53: qso_qslsince 2018-08-14
that's all, nothing fruther. then a window pops up which says "operation completed".
But no new QSL confirmations are downloaded.
Re: No download from LoTW anymore
Please state actual version number of Log4om that you have installed
No response so I assume that you found the issue which of course might have been LOTW server temporary down or some local issue on your computer like an old version of Log4OM?
I did test just to be sure all was OK and as you can see from the screen shot below it works fine
TQSL Down.jpg (80.66 KiB) Viewed 3406 times
MM0GOR
Post by MM0GOR »
I also have this issue where LOTW download does not work when trying to download from QSL management tools as below:
MM0GOR
Post by MM0GOR »
sorry I'm using version 1.37
Set debug to trace mode in help
Attempt another download
In help open show log
Save that text file to your desktop
EMAIL it to me DO NOT POST IT ON THE FORUM
My email is g4pop (at) arrl.net as shown on QRZ
