Spotter Call (opt) in Telnet Cluster window
I2782VE
Post by I2782VE »
in telnet cluster window is a "Spotter Call" label over the command field.
Attached a screenshot
Thanx.
Re: Spotter Call (opt) in Telnet Cluster window
Apologies Stefano but I don't understand your question?
I2782VE
Post by I2782VE »
next to "Invia comando" button there is a "Spotter Call (opt)" label that cover the command field.
I2782VE
Post by I2782VE »
Ok Terry,
we are talking about two different thigs.
See the new screenshot,
this "Spotter Call (opt)" text/label is covering the cluster command field.
You can type, but you can't see because of this text over the field.
Hope now is more clear.
Sorry for my bad english! :oops: :oops: :oops:
Hi Stefano,
My best suggestion is to uninstall the software, download a fresh download of the latest version and re-install.
Please make a backup before doing this as a good housekeeping choice
BTW your English is so much better than my Italian :lol: :lol: :lol:
It's strange,
the "spotter call [opt]" label should be placed just left the "set personal info" button and not where you see it.
Anyone other has the same issue?
On this end all o.K.
I2782VE
Post by I2782VE »
Tried with another PC (Win 8 x64)
With language set to English is all ok.
The problem is on Italian language
Stefano,
I still thing you should re-install as I suggested to see if it is definitely a language problem because Daniele uses the italian version and does not have the problem
I2782VE
Post by I2782VE »
Terry,
is already reinstalled.
These screenshots are from another PC (my Workstation), not from my home pc.
