Page 1 of 2
Spotter Call (opt) in Telnet Cluster window
Posted: 10 Nov 2013, 14:55
by I2782VE
in telnet cluster window is a "Spotter Call" label over the command field.
Attached a screenshot
Thanx.
Re: Spotter Call (opt) in Telnet Cluster window
Posted: 11 Nov 2013, 11:02
Apologies Stefano but I don't understand your question?
Posted: 11 Nov 2013, 11:21
by I2782VE
next to "Invia comando" button there is a "Spotter Call (opt)" label that cover the command field.
Posted: 11 Nov 2013, 12:04
by I2782VE
Ok Terry,
we are talking about two different thigs.
See the new screenshot,
this "Spotter Call (opt)" text/label is covering the cluster command field.
You can type, but you can't see because of this text over the field.
Hope now is more clear.
Sorry for my bad english!
Posted: 11 Nov 2013, 15:39
Hi Stefano,
My best suggestion is to uninstall the software, download a fresh download of the latest version and re-install.
Please make a backup before doing this as a good housekeeping choice
BTW your English is so much better than my Italian
Posted: 12 Nov 2013, 16:14
It's strange,
the "spotter call [opt]" label should be placed just left the "set personal info" button and not where you see it.
Anyone other has the same issue?
Posted: 13 Nov 2013, 11:47
by DF5WW
On this end all o.K.
Posted: 13 Nov 2013, 17:11
by I2782VE
Tried with another PC (Win 8 x64)
With language set to English is all ok.
- English.JPG (61.08 KiB) Viewed 7516 times
The problem is on Italian language
- Italiano.JPG (61.34 KiB) Viewed 7516 times
Posted: 13 Nov 2013, 17:18
Stefano,
I still thing you should re-install as I suggested to see if it is definitely a language problem because Daniele uses the italian version and does not have the problem
Posted: 13 Nov 2013, 17:26
by I2782VE
is already reinstalled.
These screenshots are from another PC (my Workstation), not from my home pc.
