Can I send N1MM+ contacts to Log4OM database?
K0HB
Post by K0HB »
I think that there is such a capability, but I haven't found any "hints" in the setup of either application.
Can someone ....
1) Confirm the capability, and
2) Point me towards to instructions to effect this capability.
(Yes, I have tried to sort through the docs, but haven't yet landed on any help)
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
NN7D
Re: Can I send N1MM+ contacts to Log4OM database?
Post by NN7D »
Hi Hans,
i assume you mean send qso's in real time from N1MM+ to Log4OM. If that is the case, yes it can be done - see page 184 of the current User's Manual dated April 7, 2019. The manual will explain the entire setup.
If you mean after the fact, you can always export the log file from N1MM+ in ADIF format, then import it into Log4OM. On import, be sure to check Update Countries in ADIF.
I hope that helps.
Doug - W7DRM
Hans
Be sure to install latest download of Log4om because this is a recent addition
K0HB
Post by K0HB »
Thanks, Doug and Terry.
DE Hans, KØHB
