Hi trying to get Log4om to display the 50mhz operating frequency, when on 50mhz
using the FTV1000 transverter. I can change the display on the FT1000 to display 50.000mhz
But using the settings in Log4om nothing changes....
I just get lost as Log4om displays 28.000mhz ?
Phil - G7BZD
FT1000MP MK5 + FTV1000
Re: FT1000MP MK5 + FTV1000
Hi Terry.
Have seen that, but how does it work. In other words how do I set it up.
Luckily I run 4mtrs on an FT847 so that should be fairly painless.
Win7 and will be using the Omnirig option.
Many thanks.
Many thanks.
Calculate the difference between the 28 mhz freq and the 50mhz freq and that's the offset
22mhz. have tried that, as thats what I thought.
Bearing in mind the ft1000 will display the 50mhz frequency as well.
Still not displaying 50mhz in the frequency window, and the band dropdown greys out displaying 10m.
Must be something I am missing.
Phil - G7BZD
Phil - G7BZD
Have tried several times to get the transverter display to read, with no success.
Putting the offset in just does not work, the frequency readout remains at 28.000mhz.
Even using the menu on the FT1000MP MK5 settings to display 50mhz, which the radio
does quite happily, Log4om remains on 28mhz, with the band tab greyed out.
Help.
Phil - G7BZD
Help.
Phil - G7BZD
Hi Phil,
Sorry for the delay but I have had a few issues to resolve.
I just tried the transverter offset and it seems to have stopped working, I will have a word with Lele and get back to you.
Phew its not me then.
Ok, Thanks Terry.
Look forward to the solution/fix.
Thanks.
Phil - G7BZD
Ok, Thanks Terry.
Thanks.
Phil - G7BZD
