Guys, I'm trying to use WSJT-X for FT8. Where and how do I configure Log4OM so whenI try to log a QSO in WSJT-X, it will show up (get logged) in my logger? I can't see anyplace in either program to make this work but I know it does as a freind has it working. Any thoughts would be greatly appreciated
73 de Kenn W5KAP
configuring so WSJT-X logs to Log4OM
Re: configuring so WSJT-X logs to Log4OM
Hi Kenn
If you take a look in the Log4OM user guide, Look on page 188 - 190.
Thanks Rolf, I will define surely check that out ASAP. I appreciate you taking the time to help.
73 de Kenn W5KAP
73 de Kenn W5KAP
Kenn,
You will see that those pages refer to JTAlert. If you aren't already using it, I highly recommend it. It logs to Log4OM, and does several other useful things as well. It also has excellent support form the developer, Laurie, VK3AMA, in the user group on groups.io
https://hamapps.com/
Jim N6VH
Jim N6VH
Thanks Jim. I'll go there now and check it out. I have a multitude of minor problems I have ot sort out. Seems my TS-2000 is not easily controlled by a computer. Sighg,may be I need a new rig!!
Thanks again
73 de Kenn W5KAP
Thanks again
73 de Kenn W5KAP
The TS2000 set the standard of excellence in CAT control, if your having issues it's either because of incorrect settings or the radio needs a manufacturers reset which is detailed in the Kenwood user guide
