Yaesu 991A - CAT Problem
Posted: 09 Aug 2019, 12:18
Hi All,
I have both an FTDX5000MPL and a 991A connected to Log4OM. I've just discovered when working /P with the 991A that it doesn't connect to the rig when on its own. The CAT status stays red and Log4OM won't display band/frequency. However, when both rigs are connected in the shack, I can switch between the two (Rig1 & Rig2) and all works as it should. It would appear that the 991A has never connected properly (it was purchased after the 5000) and it's the 5000 that's instigating the CAT somehow (as I have both rigs turned on at the same time. I can turn off the 5000 and the 991A keeps working ok on CAT. Strange...
On its own, I've turned on/off the 991A, the laptop and Log4OM in various combinations, but this doesn't fix the problem.
5000 = COM3, 991A=COM4 & COM5. Using OmniRig - I recall there were two 991 settings in OmniRig(?). Not at my rig at the moment and I can't recall which one I chose.
Any ideas please? Perhaps a copy of OmniRig settings for someone successfully using Log4OM with a 991A?
Thanks in anticipation!
Ian.
Ian.
