Cannot Save the English Manual
W4ATX
Post by W4ATX »
I hope this is not by design...I can view the English manual just fine online. When I download it and try to open, Adobe Reader (and Acrobat) complains and says the file is corrupt. And...before you ask, other files open just fine locally.
Re: Cannot Save the English Manual
Start Log4OM and then try HELP/HELP/English/Force manual download. If it´s been downloaded
try HELP/HELP/English/Open manual.
Forget what i wrote. Looks like the english manual is damaged. If i try to load it and say open with
Adobe Acrobat Reader DC i got the same error message. Can´t open it on the website ...
W4ATX wrote: 12 Aug 2019, 16:40 I hope this is not by design...I can view the English manual just fine online. When I download it and try to open, Adobe Reader (and Acrobat) complains and says the file is corrupt. And...before you ask, other files open just fine locally.
Yes it seems we have a problem because I have recreated the pdf file and uploaded it to the server and I still find the download wont open.
Please be patient it will be fixed as soon as I can get Lele's attention, sorry for the inconvenience.
If you update the user guide from the Log4OM help menu then you will find a copy that you can open in the folder named
C:\Users\YOUR USER NAME\AppData\Roaming\LogOM
The file is called Log4OM.enu.pdf
W4ATX
Post by W4ATX »
Thanks! I finally got a good copy.
